    Dynamic Component attribute question
    3 Posts 2 Posters 1.8k Views 2 Watching
    • I
      iclifton
      My question is probably a simple one. If i create an attribute to return the cost of an item based on the model number, which i already have set up in a pull down list. When i use the =if formula, i can only go out 3 cost. i have eight model numbers. Is there a different formula that i can use or am i doing something wrong.
      • P
        pcmoor
        you can use nested if statements, however it is best to use the choose function, based on the dropdown index. CHOOSE(index,value1,value2,...valueN)
        cost =choose(drop,$12,$15.....$n)
        drop item 2 (where the value =2)
        or if value of drop is some function or not a consecutive integer,
        then use OPTIONINDEX("attributeName")
        within the choose function
        cost =choose(optionindex("drop"),$12,$15.....$n)
        the number of choices = numder in dropdown
        • I
          iclifton
          Thank you pcmoor. i was able to use =CHOOSE(OPTIONINDEX. It gave me the result i was looking for. Thanks for the help!
