    Layers Sort Order
    1 Posts 1 Posters 304 Views 1 Watching
    • B
      BrianSCV
      Hi, a quick question regarding the Layer Sort Order.
      Is there a plug-in allow one to control the sort order of Layers?
      Please note: I do understand that the Layer Panel built-in to SU allows you to do this but that is for display in SU only.
      For example, if I create the layers B, C and A in that order - the Layer Panel will sort them alphabetically (A, B and C).
      However, when I import the SKP file in my application the Layers will get imported in the order of creation (B, C and A).
      As a workaround I edit the file in SU in this order:
      Cut group/items in A Layer and Paste it back in.
      Cut group/items in B Layer and Paste it back in.
      Cut group/items in C Layer and Paste it back in.
      It's a lot of work, especially if one has a lot of SKP files and lots of Layers.
      In my application, it's necessary for the Layers to appear in Order as each Layer is associated with a color and when the order is random then they will appear confusing in my interface.
      Thanks!
