    Modeling Trains - learning Sketchup
    55 Posts 16 Posters 10.2k Views 16 Watching
    • LA_RR_ArchitectL Offline
      LA_RR_Architect
      Hello everyone,
      Thanks for looking and your helpful, provocative observations.
      Hellnbak, you’re correct, I have run into the occasional problem with back facing polygons and have been attempting to ferret them out of my models. The 060 was one of my first and has been reworked several times, but still a few backward faces… so it goes.
      Bryan, Thanks and there’s probably no reason to start adjusting your monitor. These images are a tad dark. This occurs for two reasons. 3dMax and I are still pretty much on mutually suspicious terms and don’t entirely get along and also, I do like the effect of late evening or early morning light. I like the added redness, the way the low shadows fall on the model and to be honest, the reduced light which hides a fairly wild lack of detail on my models. At present, I’m working down to about 1 inch detail, I’m afraid that if I push things to the next level the size of my models will go up by an order of magnitude.
      Majid, You’re are mostly right about the level of texture. In my defense, I again site my lack of intimate familiarity with Max but also claim that the goal of the images is not to create a hyper realistic image but rather to evoke the feeling of large scale railroading as seen in the photos made in the 30’s, 40’s and 50’s when large steam powered monsters roamed the earth. It is one reason I try not to get too close to my subjects.
      One question that someone may be able to answer. If I model SU surfaces with textures, I can edit or change the texture in Max however if I use a solid color in SU all I can do with the imported file is change the color, I can’t apply a texture to it. Any idea what gives?
      In any case, get ready for another dark image… really dark. This scene features a pair of locomotives at a cross track. The crossing is guarded by a signal tower (yellow building in the foreground) in order to minimize the chance of the obvious accident. The crossing and tower are generally historic. The scene is illuminated by the two locomotive’s headlamps and a handful of 60W bulbs.
      Thanks again everyone
      Jim
        LA_RR_Architect
        Just added a new box car to my small and slowly growing collection of railroad equipment. It features an improved truck and more complete brake equipment.
        Pictures below.
        Jim
        • Bryan KB Offline
          Those look great! Are you working from engineering drawings?
            LA_RR_Architect
            Hi Bryan,
            Yes, I work from engineering drawings and photographs as I can find them. Most are partial sets of drawings either abstracted or redrawn for model builders. I look for drawings where there's enought dimensional and detail information go create a reasonable copy.
            Jim
            • Bryan KB Offline
              Thanks for the info Jim. Engineering drawings of any kind are always a big help.
              Looking good!
                LA_RR_Architect
                Hello again,
                In answer to the question that probably no one has asked: What do you do with a boxcar?
                I couple it into a train, in this case a string of mostly empties behind my switch engine.
                And the switch train? Roll it into a scene and press the render button.
                Yes, I know still kind of dark, but thanks for looking.
                Jim
                • pbacotP Offline
                  Very nice--cool and fun picturs. Yes I find your renders are dark and I wish to see the details better.
                    LA_RR_Architect
                    OK, setting asside my penchant for dramatic (moody) lighting, here's another view of my scene from another direction with the sun set to a bit closer to noon.
                    My renderings are typically at 3849x2400 resolution (twice my screen) so they have been reduced a bit to get them through the site's 1000 pixel limit. Below are two images cropped to aprox. 1000x1000 which may give you a bit better idea of the detail I see on my screen.
                    I rather enjoy the little bit of the scene I see reflected in the caboose's marker lights.
                    Once again, thanks for looking.
                    Jim
                      LA_RR_Architect
                      My current rail road themed project is Kelso Depo.
                      Kelso Depo was built by the Union Pacific in 1924 and pretty much sits in the middle of the Mojave desert, over 20 miles from the nearest highway and 35 miles from the closest town. The building still exists and is now operated by the National Park Service.
                      The model is now about 75% complete and is geo-located.
                      More to come soon. Jim
                      • deaneauD Offline
                        deaneau
                        @LA_RR_Architect
                        do you design for any railroad simulator ,too?
                        for trainz i have a sketchup plugin.
                        im sad about, that sketchup cant export animations (not movies) i mean real animations.
                        here a simple export from Lightup4sketchup to trainz.
                        lights and shadows will bake in the texture.
                        for this i dont need 3dmax.
                        MADE, BORN AND LIVING IN BERLIN
                        Big Thank You to all Programmers
                        Some German words are so long that they have a perspective. M.Twain
                          LA_RR_Architect
                          Hello,
                          Interesting images... looks like light and shadows are well handled.
                          But, no, so far, my models are static renders only.
                          The models are a bit large and for me fairly complicated mechanically, I'd love to see them move but I'm not sure how to describe the motions.
                          Also I've had a bit of a challenge getting 3dMax to render any animations - I think it doesn't like my computer. I can do large static renders but as soon as I attempt even a simple an animation, it crashes.
                          Jim
                          • deaneauD Offline
                            deaneau
                            than look at Eneroth Railroad System (ERS). ok the locos in this plugin is lowpoly..this is needed. otherwise your framerate will drop.
                            you could try highpoly..however the movement of your cars annd locos could be very slow.
                            when you design own tracks, ERS can help you to setup your cars and locos on this track.
                            your renderings look like LumenRT or Lumion
                            (sketchucation.com)
                            SketchUp Plugins | PluginStore | SketchUcation
                            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                            (sketchucation.com)
                            https://plus.google.com/110985781685543511443/videos
                            and here all videos via google
                            Google Search
                            (www.google.de)
                              LA_RR_Architect
                              I think for the moment, it's time to suspend SU modeling and begin assembling parts in 3DMax.
                              Here's where things stand this evening.
                              The station has a partial interior; floors, partitions and doors so I hope to be able to apply some useful interior lighting.
                              Cheers, Jim
                              • pbacotP Offline
                                This is great. They certainly built a good size depot for the middle of nowhere. Is is possible to go in or look inside the building today?
                                Railroads really put a lot into building up the fantasy of the west, along with many depots that were fine buildings in their own right.
                                Great job on the tile roof. Did you have any plugins or methods that helped in that, or just brute force?
                                  LA_RR_Architect
                                  Hello,
                                  The depo still exists pretty much dead in the middle of no where. The rail road abandoned use of it in 1985 and subequently sold it to the National Park Service in 1992.
                                  It is now fully, and very nicely, restored inside and out and serves as the visitor center at the Mojave National Preserve which is a 2,500 square mile preserve. A park larger than either the state of Deleware or Rhode Island. If you look at Google images of Kelso Depo, you can see how well done it is.
                                  And yes, the tile work was strictly brute force. I wasn't sure I could pull it off but it wasn't too difficult and seems to have worked pretty well.
                                  Jim
                                  • deaneauD Offline
                                    deaneau
                                    jim if you want, you can share your work in the 3dWarehouse.
                                    Pullman Buildings look very nice ,too
                                    i have seen in this week a movie about the time around the May/10/1869
                                    http://upload.wikimedia.org/wikipedia/commons/e/e4/1869-Golden_Spike.jpg
                                    The Golden Spike ceremony held at Promontory Summit, Utah on May 10, 1869. Photograph by Andrew J. Russell.
                                    • Bryan KB Offline
                                      The building looks great!
                                        LA_RR_Architect
                                        Hello folks,
                                        Here are a couple renderings including my Kelso Depo model.
                                        The backround mountains are images I made on site two weeks ago, the trees are free models from Xfrog.
                                        The third image is an enlarged detail showing roof tiles, awnings and double hung windows, gutter and downspout detail and decorative bandsawn rafter tails.
                                        I hope you enjoy, thanks for looking.
                                        Jim
                                          LA_RR_Architect
                                          Hello all,
                                          My latest project is nearing completion... this time the small but fairly fussy B&O depot at Point of Rocks, Maryland.
                                          It was modeled from the photos and drawings found in the Historic American Engineering Record Survey housed on-line at the Library of Congress. I have also consulted other on-line images of the building which still is in use.
                                          Jim
                                          • pbacotP Offline
                                            Sweet. Yes fussy. Extra decoration or contrivances seem to be features of depots--almost like follies. As if the small building needs extra help to express how fine the destination is. We had many small historical depots in our area that are gone now. Swept away with the public transport. Now a new train is going in and a new depot near our house with it's own idiosyncrasies.
                                            Very cool model. Would like to see rendering and close-ups. Thanks for sharing!
                                            • 2 / 3
