    How does does one output in hybrid in Layout?
    layout
    3 Posts 2 Posters 711 Views 2 Watching
    • D
      djh
      Sorry for the very basic question. How does does one output in hybrid in Layout? I only see options for PDF, images dwg/dxf. Is PDF called "hybrid"?
      • D
        djh
        pbacot, thank you.
        • pbacotP
          Hybrid is the rendering option for a SU model reference inside LO. If the SU model dialog window shows "hybrid" in the lower right, then that model will output (print, pdf etc.) as hybrid. It's not a sort of export.
          Hybrid is a rendering of the SU model so that the edges are vectorized (relatively hard and sharp lines) and the textures and shadows and other SU raster effects are still visible.
