    [REQ] Make Square Centered at Point
    11 Posts 5 Posters 1.4k Views 5 Watching
    • Bob JamesB Offline
      Bob James
      This seems so simple that it must already exist, but I could not find it.
      For example: I want to make a 4" square post at a specific spot. If I wanted a round post there I would just select the circle tool, place the cursor at the point and drag out (or put a value in the VCB).
      I'd like to be able to do that for a square: select tool, place the cursor at the point and drag out (or put a value in the VCB)
      I apologize if this already exists
      • JQLJ Offline
        JQL
        LOL bob you can make your life difficult if you draw a 4 sided circle and explode it.
        Or you can make your life painless if you draw a 4 sided polygon without exploding it.
        Those two are native tools. Do you forget sketchup also has native tools?
        www.casca.pt
        Visit us on facebook!
          Bob James
          Duh 😳
          (But still think it would be a useful one-click native tool) πŸ˜†
          • JQLJ Offline
            JQL
            Apologies accepted if you post it on the Duh thread!
            www.casca.pt
              Bob James
              Copied everything and ready post but can't find doh/duh thread πŸ˜’
              • cottyC Offline
                cotty
                You can bookmark it: http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=17315%26amp;p=556889#p556889
                my SketchUp gallery
                  @bob james said:
                  Duh 😳
                  The Polygon tool already is the useful native tool. It's no more work than using the circle tool.
                  • BoxB Offline
                    Plus it's even better in 2015 because you have the Ctrl modifier to adjust it.
                      Bob James
                      Done
                      But I have the extra step of entering a "4" 🀣
                        @bob james said:
                        Bob, it sounds like you've gotten soft. Man up! πŸ˜„ πŸ˜† πŸ˜†
                        • JQLJ Offline
                          JQL
                          And if you forget the "4" in the beginning you have to both press "4" and "S" later. Two key presses and you'll be dead!
                          www.casca.pt
