    DWG Import Help
    3 Posts 3 Posters 290 Views 3 Watching
    • H Offline
      Hodge182
      Hi all,
      I am a beginner with SketchUp and I am having trouble when I import a DWG file which I have been sent by an engineer.
      I do not have autocad so i cannot make changes to the file. I have opened the DWG in Adobe Illustrator and within that program the file is clearly visible (I have attached a screen shot). When I import the DWG into SketchUp, all I can see is random straight lines (screen shot attached).
      When importing the DWG, I have set the scale at metres which I believe to be correct.
      What am I doing wrong? Any help would be greatly appreciated.
      Cheers
      SketchUp Screen Shot.pdf
      Adobe Illustrator Screen Shot.pdf
        JGA
        Just about impossible to say without seeing the DWG file - are all the layers turned on, is one drawing linked to another, what version of DWG & SKUP???
        Regards,
        JGA
        • JQLJ Offline
          JQL
          You could install Draftsight or Nanocad and work the dwg there natively. They're free.
          www.casca.pt
          Visit us on facebook!
