    Mac - Materials Folders on Server
    5 Posts 2 Posters 463 Views 2 Watching
      Lersince1991
      On my PC's at work I set up a centralised materials, components, styles etc folder on the server so all workstations can edit and add materials for all. (can't remember if I changed the default location or added them as favourites destinations)
      I've since added Mac's to the mix but cannot find out how to change the default locations of materials/styles/components etc... or add them as favourites to the drop down list.
      How can I do this on a Mac please? 😲
        driven
        @lersince1991 said:
        ...but cannot find out how to change the default locations of materials/styles/components etc... or add them as favourites to the drop down list.
        How can I do this on a Mac please? :shock:
        you can't change the default locations...
        but, you can add symlinks [from your server folders] into the default 'User' folders...
        It's similar to working from 'dropBox' and I'm sure there are post's here that explain those steps...
        john
          Lersince1991
          Mission accomplished, Symbolic links in place
          Thanks!
            driven
            do you want to explain your steps for others?
            john
              Lersince1991
              Sure.
              I messed about in terminal but couldn't get it to work so I downloaded this tiny service app:
              1 - Download SymbolicLinker: http://seiryu.home.comcast.net/~seiryu/symboliclinker.html
              2 - Mount the dmg file and copy the .services file into your (Mac HD)/Library/Services (if its not there add it)
              3 - Open the SymbolicLinker.services file from the folder you just copied it into
              4 - Navigate to your server or dropbox or second hard drive - wherever you store your materials collection
              5 - right click on your materials folder and at the bottom there will be a new option saying "create symbolic link"
              6 - now select the new symbolic link it just made and copy it
              7 - Navigate into your sketchup folders ~/Library/Application Support/SketchUp 2015/SketchUp/
              if you can't see it use; finder->go->go to folder and copy that in and press enter
              8 - delete the sketchup materials folder (OR RENAME IF YOU WANT TO KEEP THE DEFAULT MATERIALS) - I've already collected these into my custom folder anyway so I just deleted them.
              9 - paste (your symbolic link) and rename to "Materials"
              All Done!
              Can do the same for style and components, you can also use these instructions to store other folders on a second drive if you use an SSD.
