    Problems with SketchUp 8 plugins in Sketchup 2015
    12 Posts 3 Posters 1.2k Views 3 Watching
      Andreas
      We try to change our SketchUp 8 plugins to SketchUp 2015. But it seems not so easy. There are several problems.
      For example:
        %(#4000FF)[**@@menu[:top]= UI.menu("Plugins")**]
      works with SketchUp 8 fine. SketchUp 2015 don´t accept that.
      I can´t find the reason.
      What´s the problem?
      With best regards from Germany
      Andreas
        I assume you are trying to assign a hash to a menu-reference ?
        Works fine provided the variable={} is predefined.
        I just tried it.
        You must assign @@menu={} as the class/module is created: it needs to be done outside of any class/module's methods that will use it later...
        for example:
        class MyClass
          @@menu={}
          def some_method()
            @@menu[;top]= UI.menu("Plugins")
        or
        module MyModule
          @@menu={} ### or @menu={} etc
          def self.some_method()
        You haven't explained why it needs to be a @@ variable ??
        Why not @menu={} ?
        Or it could just as easily be a Constant ? Menu={}
        Without seeing and understanding all of your code it's impossible to resolve this.
          Andreas
          It is a little bit complex.
          I don´t want to show hundreds of lines code here.
          So I try it like this:
          # File in SketchUp-Plugins
          require('sketchup.rb')
          require('extensions.rb')
          module ABSBMP  ### ( Toplevel namespace)
            module MoMo  ### ( This plugin's nested namespace. )
              @@relExtPfad = 'ABSBMP/mo_mo_moebel' # relative path
              @@ladeprogramm = 'mo_mo_load'        # load script
              @@plugin = SketchupExtension.new( @@sagExt;titel],File.join@@relExtPfad,@@ladeprogramm) )
              Sketchup.register_extension( @@plugin, true )
            end # module MoMo
          end # module ABSBMP
          file_loaded('Plugins;ABSBMP_mo_mo_moebel_ext')  # global method from 'Tools/sketchup.rb'
          # File (@@ladeprogramm 'mo_mo_load') in subdirectory (@@relExtPfad)
          module ABSBMP;;MoMo
            Sketchup.require(File.join(@@relExtPfad,'mo_mo_main'))
          end  # < module ABSBMP;;MoMo
          file_loaded('ABSBMP;mo_mo_load')  # global method from 'Tools/sketchup.rb'
          # File ('mo_mo_main') in subdirectory (@@relExtPfad)
          module ABSBMP;;MoMo
          end  # module ABSBMP;;MoMo
          file_loaded('ABSBMP;mo_mo_main')  # global method from 'Tools/sketchup.rb'
          Andreas
                @@menu={} ### Otherwise the hash is nil !
              Andreas
              Sorry, my mistake. It is not complete, I forgot something.
              This should be correct:
                end # module MoMo
              end # module ABSBMP
              module ABSBMP;;MoMo
              # File ('mo_mo_var_get') in subdirectory (@@relExtPfad)
              module ABSBMP;;MoMo
                ### MODUL-VARIABLEN  ( MODULE VARIABLES )
                 #{# Menüs  ( Menus )
                   @@menu = {}
              file_loaded('ABSBMP;mo_mo_var_get')  # global method from 'Tools/sketchup.rb'
              module ABSBMP;;MoMo
                  @@skript = ["mo_mo_var_get"]
                  Sketchup;;require(File.join(@@relExtPfad,@@skript))
              Andreas
                Why don't you simply set up @@menu = {}
                inside the first loading file which creates
                module ABSBMP::MoMo
                Then the loading order of the rest of the files [which seems unnecessarily complicated!] become unimportant.
                  Andreas
                  It is a large application. Therefore it is comprehensible to declare the variable in a separate file.
                  But it seems, that the real problem is included elsewhere. So I've changed my method. Till now I've tried to find out what does not work. Now I am trying to find out what works.
                  In that process I found an error in the following code:
                  module ABSBMP;;MoMo
                  class << self
                    # Proxy class inside module ABSBMP;;MoMo
                    # Create Reader methods for currently defined module variables.
                    ABSBMP;;MoMo;;class_variables.each do |varstr|
                      kind = eval %[#{varstr}.class]
                      attstr = varstr.gsub(/(\A@@)/,'')  <-- Error; #<NoMethodError; undefined method `gsub' for ;@@relExtPfad;Symbol>
                      # Reader Method
                      unless ['@@sag','@@skript'].include?(varstr)
                        eval %[def #{attstr}(); return #{varstr}; end;]
                        if kind.is_a?(TrueClass) || kind.is_a?(FalseClass)
                          eval %[alias_method('#{attstr}?','#{attstr}');]
                    end #} do class_variables.each
                  end  # Proxy class
                  %(#4040FF)[The error-message is shown at the start of SketchUp 2015.
                  In SketchUp 8 it works well!!!]
                  Andreas
                    Perhaps: varstr.to_s.gsub...
                    Since I don't understand what your code is trying to do it's not that easy to help...
                      Andreas
                      Is a good idea, but does not really works.
                      It works like this:
                         varstr = varstr.to_s
                      The names of the module variables will be reduced by the first two "@" sign.
                      This names will be used later as descriptions to make the color settings. For example for cabinet sides, cabinet doors, tabletops ...
                      We are manufacturer of office furniture.
                      http://www.momo-moebel.de/
                      The application is used to create plans for office furniture.
                      You can get the plugins as a free download for usage with SketchUp 8 from our homepage.
                      http://www.momo-moebel.de/fileadmin/service/mo_mo_SketchUp_V_3_2_06.zip
                      We want to offer that for current sketchup Versions. Therefore, we are reworking the SketchUp plugins.
                      Andreas
                        So your code
                        ABSBMP::MoMo::class_variables
                        returns an Array of Symbols
                        >>> [:@@a, :@@b,...]
                        So you need the step varstr = varstr.to_s to make it into a String.
                        :@@a >>> "@@a"
                        Then you use attstr = varstr.gsub(/^[@][@]/, "") to strip off the initial '@@'...
                        • Dan RathbunD Offline
                          Dan Rathbun
                          should be just:
                          @@skript = "mo_mo_var_get"
                          I'm not here much anymore.
                            Dan Rathbun
                            @tig said:
                            So your code
                            >>> [:@@a, :@@b,...]
                            :@@a >>> "@@a"
                            Many of the global query methods changed from Ruby 1.8 to Ruby 2.0.
                            They now return arrays of symbols (for each variable or method name.) In Ruby 1.8 they returned array of string (for each variable or method name.)
                            There are also many other "breaking changes" in Ruby 2.0 that need to be dealt with.
                            (@TIG, Was there a post here on breaking changes?)
                            Also garbage collection is much better under Ruby 2.0, so any menu reference will most likely only be valid during the evaluation of the file in which the reference is first made by an API call.
                            So the attempt to hold the reference @@menu[:top] across multiple files may no longer work.
                            We have been complaining about the non persistence of UI element references, for years! (Especially menu references.)
                            So the workaround is to save the menu NAME (as a string,) instead of the actual reference to the menu object.
                            @@menu[:top]= "Plugins"
                            ... then whenever you need the object reference, use:
                            topmenu = UI.menu( @@menu[:top] )
                            or
                            submenu = UI.menu( @@menu[:top] ).add_submenu( "MoMo" )
