    Layer Control
    7 Posts 3 Posters 690 Views 3 Watching
    • kenK Offline
      ken
      I have a model with numerous layers. Is there a context menu plugin, this if I left click on a part, the part is highlight/selected, and then in the context menu, right clikc, a selection to turn whatever layer this part is on, to turn that layer off?
      Such, that I left click, make selection, right click and select "turn layer off", and then that layer is turned off, alone with all object on this layer being turned off. Note, I don't want to hide the selection, I want to turn the selection's layer off.
      Thanks for you time.
      Ken
      • Bob JamesB Offline
        Bob James
        jiminy-billy-bob's Layer Panel V 1.2.1 will do this
        • kenK Offline
          ken
          Bob
          I looked at layer panel, all I could see it would highlight the layer the object was on, then allow me to turn off the layer. And that may be what I end up using, however, I just wanted two clicks.
          Thank you for your reply.
          Ken
          • F Offline
            fountainhead
            Use Didier's Layer Manager, there is an icon "hide layers of selection" in the toobar...I use it all the time.
            • kenK Offline
              ken
              I have Didier's Layer Manager, however, it does not seem to work in V 2015. No selection on the menu bar works.
              Thanks for you reply
              Ken
              • F Offline
                fountainhead
                You need to change one line of code at the end of some of Didier's scripts to work with 2014 and 2015, unfortunately I don't remember what that small change was. Message Tig, I think he suggested the easy fix.
                • kenK Offline
                  ken
                  Thanks, I'll do a search, I am almost sure I saw something about that, now that you reminded me.
                  Thanks for the reply.
                  Ken
