    Escaping out of editing a component
    4 Posts 3 Posters 529 Views 3 Watching
    • F
      Frankn
      Sorry if this has been asked before but I searched and can't find an answer... though admittedly I'm not sure what to search for so I'll explain it best as I can...
      When editing a group or component we can use the escape key to exit 'edit mode'... is there a way to do this with ruby? I tried
      @model.selection.clear
      but that doesn't work. I included a picture to help explain what I mean.
      • TIGT
        Something like:
        model.close_active
        Which goes up one level...
        To go all the way back to the model.entities context use:
        model.close_active until model.active_entities==model.entities
        • F
          Frankn
          UUgghhh never thought of searching for something with 'close' in it kept thinking 'escape'!
          Thanks Tig! You da man... well tiger!
          This is the code I'm using... anything more efficient?
          while @model.active_entities!=@model.entities
                 @model.close_active
          • tt_suT
            tt_su
            Note that if only close the currently open instance. If you are deeply nested you need to loop until you are back in the root - (if that's what you desire). And before SU2014 the method was bugged and could mess up geometry if the close was undone. (The method actually creates an undo item)
