    Key combinations
    5 Posts 3 Posters 480 Views 3 Watching
    • CadFatherC Offline
      CadFather
      does anyone know if you can use multiple acc keys? like CTRL+ALT
      i looked around and saw nothing, tried with && check but no results (the first key has priority)
      another 'sorry can't do'?
      • PixeroP Offline
        Pixero
        Maybe something like this:
        def onKeyDown(key, repeat, flags, view)
        if key == altKey
            altDown = true
        end #if
        if key == controlKey
             controlDown = true
        end #if
        if altDown && controlDown == true
           #do stuff here
        end# def
        def onKeyUp(key, repeat, flags, view)
            if key == altKey
                 altDown = false
            end #if
                controlDown = false
            end #if
        end #def
          slbaumgartner
          The flags argument passed to onKeyDown and onKeyUp tells you the state of the modifier keys. It is a bit mask with bits set for the keys that are pressed. You can figure them out by printing the flag values you get for various combinations. However, I believe they are OS-specific and sometimes hardware dependent.
            CadFather
            Thanks Guys, i'll have a look at Jan's table. can't believe it's so messy working with the keyboard.
              slbaumgartner
              Yes, messy - but the mess originates in the OS, not SketchUp!
