    OnKey_Downer!
    7 Posts 3 Posters 823 Views 3 Watching
    • CadFatherC
      CadFather
      read through some of the old posts but didn't find anything a one neuron coding master could actually use.
      Fredo6 pointed to a thru paint animation routine to achieve a Typematic effect. i looked through the code but i realise i'm not ready for a lobotomy yet.
      has no one worked this one out, can't we 'just' keep a button down and have it repeat?
      Looking at Pixero's JSmover, (which is a real gem) - i was hoping to add 2 features:
      1. repeat on key press
      2. make it follow a slope if on one. (perhaps combining some sort of drop to intersection procedure)
      dreamland i know, but really we have quite a few great plugins that could be 'perfected'!
      • D
        driven
        you can do with the arrow keys? .e.g. jf_Mover2.rb...
        it also works with WASD,
        but on a mac, that requires 'ApplePressAndHoldEnabled' to overide the context menu for text replacement options...
        knight's game works as well and uses a ray-test for face to detect terrain under foot...
        so, both are doable...
        john
        • CadFatherC
          CadFather
          thanks Driven, i know even a few camera moving scripts do it but just couldn't 'get' the code to tweak, so i thought i'd check for some kind of routine/snippet that could be integrated.
          this is what i was looking at: http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=24327#p239409
          • D
            driven
            as far as my tests go that one no longer even works on mac...
            all the ones I know involve WebDialogs actively capturing the keys, otherwise you would need to disable all shortcut keys...
            john
            • CadFatherC
              CadFather
              πŸ˜’ goodness so many scripts could do with this 'basic' functionality.
              thanks for testing it - i should have done so, had only looked at the code 😞
              • fredo6F
                fredo6
                Actually, I don't use Repeat key down, but simply the animation mechanism (nextframe method). Keyboard management in the SU API is very rudimentary and repeat does not work consistently.
                Fredo
                • CadFatherC
                  CadFather
                  i guess one workaround is to make a webdialog tiny enough not to intrude 😲 but able to 'catch' the keystrokes repeating...
