    Sketchup crashes when import,purge_unused,export dae files
    1 Posts 1 Posters 316 Views 1 Watching
    • Y
      YoungOSG
      Sketchup crashes when import,purge_unused,export hundreds of *.dae files.
      I use api to do this.It works fine while handling few *.dae files.
      anyone konws why?
      Here is my code
      require 'sketchup.rb'
      require 'fileutils'
      UI.menu("Plugins").add_item("purge_multi_daeE") {
      @import_folder = selectImportDaefolder()
      break if @import_folder==nil
      @export_folder = selectExportDaefolder()
      break if @export_folder==nil
      @daeFiles = getDaeFiles(@import_folder,".dae")
      purgeDaeFile(@daeFiles,@import_folder,@export_folder)
      Sketchup.send_action("selectSelectionTool:")
      def purgeDaeFile(daeFiles, import_folder,export_folder)
      model = Sketchup.active_model
      subName = getDirName(import_folder)
      Dir.chdir(export_folder)
      FileUtils.rm_r subName if Dir.exist?(subName)
      i = 0
      Dir.mkdir(subName)
      daeFiles.each{|singleDaeFile|
      	Sketchup::set_status_text("purge " + File.basename(singleDaeFile))
          status = Sketchup.active_model.definitions.purge_unused
      	f.puts(singleDaeFile)
      	importDaeFile(singleDaeFile)
      	purgeModel()
      	resultFileName = File.join(export_folder,subName,File.basename(singleDaeFile))
      	Sketchup.active_model.export(resultFileName, false)
      	deleteLastModel()
      end#def
      purge dae model
      def purgeModel()
      # 1. purge styles
      styles = Sketchup.active_model.styles
      status = styles.purge_unused
      # 2. purge materials
      materials = Sketchup.active_model.materials
      materials.purge_unused
      # 3. purge definitions
       definitions = Sketchup.active_model.definitions
       status = definitions.purge_unused
      # 4. purge layers
      layers = Sketchup.active_model.layers
      status = layers.purge_unused
      end#def
      导入dae file
      def importDaeFile(singleDaeFile)
      model.import(singleDaeFile,false)
      entities = model.entities
      definitions = model.definitions
      definitions.each {|definition|
      transformation = Geom::Transformation.new([0,0,0])
      componentinstance = entities.add_instance(definition, transformation)
      end#def
      def deleteLastModel()
      entities = model.active_entities
      entities.erase_entities entities.to_a
      end#def
