    [proto] Quick Scene Dial
    6 Posts 3 Posters 981 Views 3 Watching
    • K Offline
      kaas
      Here's a preview of a small plugin for managing scenes. It allows you to:
      1. create named sets of scenes. Scenes can be in several sets
      2. switch to a scene
      3. hide the Sketchup Scene Tabs - create more working screen space
      4. hide (just don't include in a set) scene names that you don't want to visually share (during a presentation for instance)
      The set info is saved as an attribute to your Sketchup file. Works in Sketchup 2015 in Win.
      edit 2 feb: plugin development stopped for the time being.
      • JQLJ Offline
        JQL
        Kaas, I have no doubt about this one... I would definetely USE it! Do you want a beta tester?
        www.casca.pt
        Visit us on facebook!
        • K Offline
          kaas
          @jql said:
          ... Do you want a beta tester?
          Would be nice. Have a look at your pm.
          • JClementsJ Offline
            JClements
            Would there be a way for a scene to execute the extents of a model so as the geometry increases or decreases, its extents are viewed for that scene when it is first opened?
            • JQLJ Offline
              JQL
              That would be great if it wouldn't pervert Layout viewports. I.E. if a scene for a floor plan has a different setting than it was created it will shift inside Layout.
              www.casca.pt
              • K Offline
                kaas
                Technically I think it is possible to do both. It would need another tickbox in the settings/edit screen for each line. Good suggestion. Will add it to the list.
