    Import Sketchup file into Artlantis
    5 Posts 2 Posters 6.5k Views 2 Watching
    • W Offline
      walter886
      Hello guys! I'm rather new in using Sketchup, so I need some help. I'm using Sketchup 2014 (and I want to render my file in Artlantis) and there is no option to export file as .atl file. Does anybody know how to do that? Is there any plugin for that.
      Thanks in advance.
        dtrarch
        Hi Walter
        I still use ATL 4.1.8 so here is my work-around.
        The last ATL2SU for this version is for SU 2014.
        (see older versions)
        I save the 2015 SU file as v2014 and then can export to ATL.
        If you have ATL v5 the updated plugins for SU 2015 are on the Artlantis website.
        Hope this helps.
        dtr
        • W Offline
          walter886
          Hi dtr.
          I have Artlantis 4.1.7.0 and Sketchup 2015. When I save file as Sketchup 2014, I still don't have the option to save as atl file. How do you that? I'm trying to use path File-Export-3D model (and there is no option to save as atl file).
            dtrarch
            Hi Walter
            There is no SU 2015 to Atl 4 export available. πŸ‘Ž πŸ‘Ž
            Just SU 2015 to ATL 5 and later.
            I do my work in SU 2015 Pro and save as a SU v2014 for export to atl.
            Also save as SU 2015 as the work file.
            Good idea to save with a SU version indication for the export and work file. β˜€
            dtr
              dtrarch
              Walter
              Use SU version 2014 and get SU2Atl plugin from ATL.
              This will NOT work in SU 2015)
              (found in "older" section of ATL downloads)
