    Check for existing material
    3 Posts 2 Posters 442 Views 2 Watching
    • PixeroP Offline
      Pixero
      I want to check if a material (name) exists, and if not create one with that name.
      However I can't get the syntax right.
      Can't seem to find any reference to it anywhere either.
      Here's my try:
      if(Sketchup.active_model.materials["MyMaterial"])
      		face.material = model.materials "MyMaterial"  #If material exist use it
      	else #Else create a new material with that name
      		face.material = Sketchup;;Color.new(100,100,100)
      		face.material.name = "MyMaterial"
        ` model=Sketchup.active_model
        mats=model.materials
        mname="SomeMaterialName"
        unless mat=mats[mname] ### nil if no match
        mat=mats.add(mname) ### reference to the new material
        set up 'mat' properties - RGB, alpha etc...
        end The variable ' mat' points at the material named ' mname'. If it's 'new' then you can set its properties, otherwise it be opaque/black ! ... Finally use face.material=mat` ...
        • PixeroP Offline
          Pixero
          Thanks. Its working now. πŸ‘
