    [Plugin] TIG_ReportConverter
    27 Posts 9 Posters 11.6k Views 9 Watching
    • BarbaraDB Offline
      BarbaraD
      I'm afraid my english doesn't reach a disussion.
      But the image shows more than words can say.
      Hope this is helpful.
      Importing with LibreOffice (OpenSorce)
      Converter v1.5
      Last but not least the Faktor!
        OK Barbara[D],
        I guess this is a follow up from an earlier discussion, 'elsewhere'.
        I believe that the Generate-Report CSV made in the German locale still uses '.' as the decimal separator.
        Your Excel setting might well then display the data using ,
        I am aware of the two competing conventions for decimal-points [. versus ,] and separating 'thousands':
        UK/USA etc 1,234.5 or 1 234.5
        and EU etc 1.234,5 or 1 234,5
        But as far as I can see those settings don't affect the original CSV format.
        It is not formatted to locale in the original CSV or the converted version.
        If you use the v1.5 is it converted OK ?
        That is, inches >>> metres !
        The 'format' is unchanged.
        Can you post the original CSV and the converted CSV.
        ZIP then so they can be attached to a post.
        You'll probably need to get at least one more post approved by an Admin before you can make attachments...
        • N Offline
          Neroro
          @tig said:
          This fix now looks for a match to /[Vv][Oo][Ll][Uu][Mm][Ee]/ in the column header [this applies to all Latin based alphabets], or a match to 'Volume' translated into various other locales - like RU,JA,KO,CH
          Hopefully this will now resolve the issues reported from other locales...
          Will the Plugin contain "zh-tw" in future?
          Chinese characters be replaced by '?'
            It's hard to fix non-ASCII characters in the reports.
            The best it can do is not-trip up on them.
            Also with <= v2013 I think it would not be possible at all.
            My only intention is to change lengths and volumes from the default 'inches' into the user's choice - say 'meters'.
            • H Offline
              HandShake
              hello - i installed this plugin and it does a great job - many thanx
              yet - i went to great trouble to have the 'dot' or '.' that i have on teh numeric key pad to make a 'comma' so that it would work in a spreadsheet to seperate entires from decimals in the language setting - i believe - that i have.
              now, after applying the plugin, the colums for values come with the 'dot'seperator --- uuuugh
              so - may spreadsheet program sees them as texts and not as numbers - bugger.
              can i fix this without changing the setting i went through trouble to make?
              many thanx
              geert-hugo
              • BarbaraDB Offline
                BarbaraD
                I will make a new modell without IFC import. Maybe it will be easier to read.
                Edit:
                v1.5 almost perfect now.
                By importing, I forgot to unhock the space seperator.
                In colum A there are more words with space. That toggled the colums.
                Don't really need colum A + B. What are they for? Rather groups and komponents would be helpfull.
                Edit:
                Hi TIG,
                what happend to the Report in SU 2016? That's nothing I would need. πŸ‘Ώ
                The Converter dosen't work anymore. What a pitty. 😒
                Made new files and it looks much better. Congratulations it is Meter.
                  saldstudio
                  thank very much for the plugin it save a lot of time! great job!
                  • 2 / 2
