    Need help in drawing patterns on walls
    4 Posts 4 Posters 7.7k Views 4 Watching
    • E
      emadshoora
      **Hello ,,
      i'm sorry if this is not the appropriate section for this post
      I need help in drawing some patterns or openings on the walls like this picture
      http://www.asergeev.com/p/xl-2011-930-23/doha_qatar_april-patterned_brise_soleil_metal_grid.jpg
      I draw the pattern wish i want by auto cad, but how i can implement it on my buildings wall on sketch up ?
      thank you **
      • D
        d12dozr
        Hello Emad,
        You can use Sketchup Pro or a DWG/DXF import plugin to bring your AutoCAD drawing into Sketchup. Then use MakeFaces or another plugin to create a surface you can push/pull. Stand the imported drawing up vertical, and push/pull to create thickness. Then you can use the Shapebender plugin to match the curvature of the wall.
        http://goo.gl/f7ooYh
        • pbacotP
          Look at the possibility of using a transparent png texture as well. Would love to see what you come up with!
          • S
            sarahjames
            Pbacot gives you a good suggestion you may also try transparent PNG textures also.
