    Unexpected behavior saving styles with scenes
    26 Posts 5 Posters 2.3k Views 5 Watching
      driven
      have you ever gotten really lost...
      then some time later make the same journey...
      you recall the route exactly, turn by turn, until you end up lost again...
      that's me...
      john
        LOL. So that was you standing next to me with the bewildered look on your face that one day a couple of months back?
        • pbacotP Offline
          Weeell I think LO should flip through scenes and take them up not per current settings but as they were saved. What if you have a scene that is a different style? I bet it flips it back to obeying saved scene styles thereafter. Once they've set it up properly, people shouldn't have to "make sure" every step of the way of what's supposed to be an integrated system.
          • MsketcherM Offline
            Msketcher
            @dave r said:
            @msketcher said:
            ...you think you're just going crazy.
            Are you sure you aren't?
            πŸ˜† Sorry. It was an easy opening.
            I learned a long time ago with LO to make sure that my SU model shows no un-updated styles; that is, no styles which display the circular arrows over the thumbnail; before saving the file and going or returning to LO. if I make a change to a style setting, I click on the thumbnail to update the style or, I right click on the scene tab and choose Update from the context menu. If the style is different from the scene's definition, the warning box pops up asking what to do with the style. Some people do turn off that warning box and that seems to create all kinds of trouble for them.
            Dave, you might be missing the point. I DON'T want the style to update. I'm just making a temporary change to a style setting to help me while modeling. I don't want those temporary changes to affect my scenes, and I wouldn't expect them to because I never followed through and clicked "Update Style." But SketchUp pushes those temporary overrides to all scenes that are using that style.
            SketchUp shouldn't change a scenes' style unless the style has been actually updated by the user.
              I did miss that. What happens if you turn off Auto Render in LO?
                Msketcher
                Auto Render in LayOut isn't really the right answer to the problem. If you simply switch to a different style in SketchUp, or "reload" the style you're on, the temporary style changes are forgotten and you're good to go.
                It's just that if you make temporary changes to the style, and save your model as-is, you'll get into trouble. It's a good trap for people who don't know what's happening. Because once you open SketchUp again to check your model, your first instinct is to go click on the style to make sure the settings are correct, and sure enough, they will be. So it's confusing.
                • 2 / 2
