    Glue a text to a face in ruby
    2 Posts 2 Posters 604 Views 2 Watching
    • N
      nicoiweins
      I would like to reproduce the text tool with the Ruby API
      I am able to select a face, to get its center, to generate a text with an arrow pointing this center point but when I move the text the point moves too. I would like the point to stay connected to the center of my face (like using the native sketchup text tool)
      I do not want to group the text and the face, I would like the same behaviour than the original tool
      Any idea?
      model=Sketchup.active_model
      ents=model.active_entities
      sel=model.selection
      vec=[10,10,10]
      sel.each{|el|
        if el.is_a? Sketchup;;Face
          bbox = el.bounds
          point = bbox.center
          tt = "Her I am"
          txt=ents.add_text(tt,point,vec)
      • TIGT
        You cannot 'associate' text with geometry at its insertion point, through the API.
        It has long been asked for...
        There are a couple of workarounds...
        Make it as 'flat' 3d-text [or normal Text] - make it inside a component definition, which has is2d gluing behavior, add_instance of it at the face.bounds.center point, then use instance.glued_to=face so it moves with the face...
