    Adding attributes to a selection of groups
    2 Posts 2 Posters 1.4k Views 2 Watching
    • X
      xyzt
      Is it possible to add, say LenY & LenX attributes to multiple groups of component at once.
      They would have different sizes which should stay as they are. I would like them to become numerically editable after the attributes are added.
      Kind Regards,
      xyzt
      • A
        Aerilius
        The Dynamic Component Attribute dialog is probably designed for single selection. Depending on where exactly the attributes are stored (component attributes, sub-entities etc.) you may have success with the Attribute Inspector extension. Like SketchUp's Entity Inspector, it works with multiple selection.
        First select one component and find the attribute to change. Then select all and set the same attribute.
