    Importing DEMS; Is there a DEM file size limit?
    1 Posts 1 Posters 175 Views 1 Watching
    • O
      olso5345
      Hello,
      I have a trial version of SU Pro 2015, trying to import a .dem. The .dem file size is ~100MB. It starts to import, then bug splat. Is the file size likely the problem? At the start of import, I reduced the number of points and faces down quite low just as a test, but still no luck. Any suggestions? Thanks, Jeff
