    SketchUp Pro 2015 User, Expired. Closes without License
    2 Posts 2 Posters 7.0k Views 2 Watching
    • T
      Timoko
      When opening the program, ADD LICENSE window is openened and without license program don't start as free version. Program is closed.
      I have Repaired, Re-installed without removing the program ( due to may extensions I have installed).
      No help. Is there a license to change program to free version?
      Most likely I have to remove program and start from clear table?
      There was no problems with 2014.
      • BoxB
        I'm guessing you need to install the free version (Make).
        I think they have made it that if you install Make on Windows you get a free trial of pro then it reverts to Make, but if you install pro, it's free for the trial period but then stops working. From what I know Mac reverts.
        Removing Pro and installing Make should have no affect on your extensions as they are stored in a separate folder.
        You can download Make from here.
        http://www.sketchup.com/download/all
