How to Import Kerkythea Materials into Sketchup Library
hi everybody!
I'm trying to import materials from Kerkythea into Sketchup library, unsuccessfully. I'm doing as follows: with the Sketchup open, I'm going in "Plugins/Kerkythea Exporter/Import KT materials" and I'm selecting the KT materials file (eg. NK metals.mat.zip). When I press OK button, nothing happens. Even after pressing "KT Materials Update/Detach", nothing new happens. I go in the Sketchup materials library to see if it is in there but, I see no new material.
What should I try different? What's wrong? If any of you help with this deal, I'd appreciate.
Thanks in advance.
maybe I can help you:
it is important to agree the entire list of your KT-Material-Libraries. Then you can attach the selected material or you see the message that the material is attached and you will find it in the SU-Material-Editor. -
I don't suppose you ever got this sorted? I'm having the same difficulty and can't find anything! Am I right in thinking a different popup should open, rather than the file explorer?
Register LoginAdvertisement
