Ruby : Get dimensions of a transformed element
Hi there,
I have a problem with dimensions of a group which has been transformed with the scale tool
(or the edges of a group)before and after the transformation, I get the same dimensions.
here is my script :
myEdges= [] entGroup = myGroup.entities entGroup .each do |e| if e.is_a? Sketchup;;Edge myEdges<< e.length end end puts myEdgesIs there a better way to get my dimensions using Ruby?
using boundingbox I have the same problem
bbox = myGroup.local_bounds widthBox = bbox.width depthBox = bbox.depth heightBox = bbox.heightThanks for your help
Nicolas
You need to take into account the transformation of the group when looking at distances, thus:
g=Sketchup.active_model.selection[0]; g.entities.grep(Sketchup;;Edge).each{|e| p (e.start.position.transform(puts; g.transformation).vector_to(e.end.position.transform(g.transformation))).length ; p e.length}; puts;Make a group [say a square that's 10 inches], make a copy, scale one of those groups, select the original sized one, paste this code in the Ruby Console + <enter>.
Then repeat the selection and code for the scaled one.
Your output for each is in pairs - the transformed distance between each vertex and the edge length.
The unscaled one returns matching pairs, but the scaled one gives the transformed distance and the original length...
OK it seems great and for a bounding box?
Thank you TIG for your help
I wrote this function
def getLength pt1,pt2,myGroup myLength = (pt1.transform(myGroup.transformation).vector_to(pt2.transform(myGroup.transformation))).length return myLength end # # for the boundingbox of the group myGroup # width = getLongueur bbox.corner(0),bbox.corner(1),myGroup # depth = getLongueur bbox.corner(0),bbox.corner(2),monGroup # height = getLongueur bbox.corner(0),bbox.corner(4),monGroup # # for a edge myEdge of the group myGroup # length = getLongueur myEdge.start.position,myEdge.end.position,myGroup -
use
group_instance.bounds()
which is inherited fromSketchup::Drawingelement, the superclass ofSketchup::Group(and most all model objects that are seen.) Even more model objects are descended fromSketchup::Entity, includingSketchup::Drawingelement. Each Ruby class inherits from it's ancestor classes.
Register LoginAdvertisement
