    More 2015 Plugin/Extension problems.
    6 Posts 3 Posters 383 Views 3 Watching
    • david_hD Offline
      david_h
      I have tried installing my old ProfileBuilder (licensed) with an RBZ workaround as per suggestions by Jeff Hammond and others. PB works fine doing that other than the menu will not display a thumbnail of the selected geometry.
      • BoxB Offline
        Installing the old version won't work.
        Download and install the new version from smustard, your license will work with it.
        It has been specifically edited to fix the preview issue.
        Even the one in the plugin store is good.
        • david_hD Offline
          david_h
          Thanks. I figgered as much. Problem is. .. I am not sure where I find my license. Does PB post that anywhere?
          • KrisidiousK Offline
            Krisidious
            Smustard tool bar installs and follows your email... I think. Smustard toolbar should do you.
            By: Kristoff Rand
            • david_hD Offline
              david_h
              Thanks. I loaded the Smustard toolbar. But It has me down for an old email address. How do I change that. I don't see a profile tab on the smustard home page.
                Krisidious
                look on the toolbar page. it has instruction at the bottom for a ruby command to remove old email.
                By: Kristoff Rand
