    Multiple joints and changing statuses.
    20 Posts 4 Posters 10.7k Views 4 Watching
    • D
      deskpilot
      OK, so I've modeled a lever operated retractable nose wheel assembly for an Ultra-light aircraft. It has 1 servo,7 hinges and 1 slider. My problem is, every time I connect a secondary hinge, my groups change status. How do I over come this problem.
      Secondary question, why does 'Solid-solver' insist on breaking groups when a hinge is affixed? ie, item is no longer a solid in it's own right.
      I wanted to post the file but there's no simple explanation of how to do it. Copy and paste doesn't work. Who-ever said that SP was frustrating, made to ultimate statement.
      • A
        Anton_S
        To post a file, use upload attachment tab, and head on from there. It's below the save draft button in the reply section...
        Once you upload the model, I could at least understand what you want. But right now I have no clue.
        I agree with the fact that SP is frustrating. I remember how I tried to figure out how to use joint myself. There was no documentation of any kind, nor there is any good documentation today. It was such a waste of time, until I thought to examine various SketchyPhysics models at 3D Warehouse. It was then when I learned how to use SketchyPhysics. If you want to learn, you might want to search 3d warehouse for SketchyPhysics, and sort options by popularity. Once you come across the model you might be interested in, download the model (non-directly) open it, play it, and then examine how it works.
        Other than that, just upload the model, and I'll see what could be done. πŸ˜‰
        • D
          deskpilot
          Thanks Anton.
          Operation is , push lever forward and wheel should lower until the 'over-center' assembly 'limit stops' meet each other. The wheel is finally locked by the weight of the aircraft acting as a back pressure trying to force the o-c assembly further over center. There may well be errors in the actual sizing of each part but hopefully, the joints will stay centered on each 'pivot point'
          Attempt number 3, Not sure what I'm doing wrong but file not showing in preview.Try again.
          Edit. What the hell am I doing wrong? Frustration, frustration, frustration. 😑
          • A
            Anton_S
            Click on that image below. It will show you in steps how to upload files.
            • BoxB
              And it needs to be smaller than 4mb to upload.
              • D
                deskpilot
                Thanks Box, that might be the answer. My model is 4.8mb. Will see what I can delete and try again.
                • BoxB
                  Delete and Purge.
                  • D
                    deskpilot
                    Desperate measure, one zip file. Hope this works.
                    Over-center lock mechanism-raised1.7z
                    • A
                      Anton_S
                      Here, I got it all fixed!
                      1. Your model was reduced up to 4 times in size, simply by purging unused definitions. I suggest you to use TT Cleanup plugin for that...
                      2. There were many faces that were misoriented and not intersected with other faces, which prevented many groups from being solids.
                      3. There are many sketchyphysics flaws you had in the model, but how could I expect it to be perfect when there are no documentation rules or what so ever. I fixed it all up, and hope you can find various things you did wrong. I don't want to explain every single detail, but hope you can figure it out after some good experience.
                        Anyway, here is the model. I added two slider controls. One to lift wheel and the other to rotate it.
                      Over-center lock mechanism-raised1.skp
                      • D
                        deskpilot
                        Thanks Anton. This raises more questions.
                        I purged every group with the built in purge function and used SolidSolver to check them out. So what's happening there. Could I have a problem within my program?
                        I will download the plugin you've suggested to check some other models.
                        Your solution, whilst proving it can be done, is, I'm sorry to say, incorrect.
                        The control lever servo, the 'over-center' assembly center hinge and the nose-wheel leg bottom hinge, should all be connected to the 'wooden structure' ie, the airframe. They are not so the model works in a curious way. I'm not at all worried about movement on the ground other than, if model, to prove that the over-center assembly does actually lock. At the moment it only half closes. I will try to correct it with out stuffing up your work.
                        Cheers, Doug
                        • D
                          deskpilot
                          Me again Anton. Been looking at fixing my problems but have come upon a wall. You've hidden the joints and I can't find any info on how to un-hide them. Looked at 'sections' but that's no help. What plugin do you use?
                          I've found one reason that stops the wheel from fully lowering. The 'u' shaped fulcrum on the lever it too shallow and jams so as to prevent the lever going fully forward. I have increased the length of the 'u' shaped part whilst keeping the group the same length. In doing this, I've lost your servo and joint connections.
                          Can you spare the time to guide me please.
                          PS, I can't see new joints if I try to make one.
                          • A
                            Anton_S
                            When I uploaded the model, most of your groups were solids. The reason you didn't see some of them as solids was because they consisted of multiple groups, i.e a group consiting of grouped lever and two joints. You have to go to the deepest level group which contains lines and faces geometry, and then check if its solid, but there is no need to do that. SketchyPhysics aint cares if the group is solid or not. As long as you set shape to convexhull2, or compound2, your group will generate proper collision.
                            To see the joints, open the layers dialog in Window > Layers, and check the Physics Joints checkbox option. When playing with the model it's a good practice to turn off physics joints layer so joints don't distract the view.
                            Right now, I have trouble figuring out which lever looks like a 'u'. I might need to return to first grade and relearn the alphabet. πŸ˜† Can you upload the model once again (through the private message if you wish) and I will fix it all up. Along with that I will provide some explanation, so you have some idea of fixing such things yourself.
                            • D
                              deskpilot
                              Hi Anton. I want to make some changes and improve some of my modelling. Then I'll resend the file but if you don't mind, please keep it on line so that others may learn from what you have to say. give me a day or so.
                              Cheers.
                              • A
                                Anton_S
                                No problem. I'll be glad to fix it.
                                • D
                                  deskpilot
                                  Anton, I've tried, my God I've tried. How the hell do you do it. LOL
                                  Firstly let me explain the changes to my model.
                                  I've reworked some of the parts. Yes, there were(and still are) many modelling errors.
                                  The 2 blue parts make up the 'over-center' lock (o/c).
                                  The purple part is the 'u' you couldn't see. This was originally jamming with the lever when in fully forward position. I've lengthened the tongs.
                                  All parts cleaned up with ttcleanup2(not that I fully understand that particular plugin).
                                  Now, this might be a step too far but I want to see the operation of the o/c assy when the Earth is moved away. Look closely and you'll see that the weight of the aircraft holds the 2 upward pointing thumbs in contact and thus locked (middle pivot is lower than the 2 end ones). This didn't happen in the previous version as the thumbs intersected each other (not solid).
                                  By 'taking off' (lowering the Earth) the o/c lock should automatically align all 3 pivot points. This is prior to moving the lever. i.e. the wheel must have weight to pull it into it's free position.
                                  The lever needs to be set so that it starts at it's zero point (not mid point) with lever fully forward. Hopefully, the wheel will rise to a point where just an inch or so is still below the blue foam (covered with F/glass)lower fuselage. This is so that in the even of a wheels up landing, the skin isn't dragged along the ground. Main wheels will be same.
                                  If my geometry is wrong, the whole thing should jam up, but I hope not.
                                  For my benefit and those others following this thread, can you explain how you decide the order in which you do things and why.
                                  Asking too much, I hope not.
                                  Do I need to put comment?
                                  • A
                                    Anton_S
                                    To make things easier for you to understand, I decided to create a video: https://www.youtube.com/watch?v=qw2C9goxbNk
                                    I'm currently in the process of adding description annotations to the video. Edit: Done πŸ˜„
                                    Here is the model:
                                    over-center_lock_mechanism.skp
                                    Hope it can teach something.
                                    • cottyC
                                      cotty
                                      Nice video!
                                      my SketchUp gallery
                                      • D
                                        deskpilot
                                        Thanks Anton. Very nice presentation and result. You mis-understood the use of the grass but no matter. That was only an extra. The main thing is that the system will work in reality.
                                        Next question, if I add the main wheel systems to this, will I loose your current 'state' for this part? I would need to edit the sliding tube and then add the rest of the system.
                                        • A
                                          Anton_S
                                          I know (as you stated) this mechanism is not finished, but I wanted to inform you of a minor flaw. Just so you get it fixed before you start preparing some parts...
                                          Well, if you explode the sliding tube group which is connected to two joints, the connection data will be lost, along with that all the properties, such as script, state, and shape would be lost too. So, once you regroup it once again be sure to reconnect it to its original joints, set it noncollidable, and add script to set it an identical mass. However, you won't need to update properties for the rest of the system as long as you don't explode the parts of the rest of the system. But if you do explode, just do what you need, put it back in group, and reapply the properties. It will be very easy if you get some experience.
                                          • D
                                            deskpilot
                                            Thanks Anton. I hadn't noticed that group conflict.Will fix it when I'm ready to add the rest of the system.
                                            Again, thanks for your tuition, just hope my 72 year old brain can remember it.
