    DC - Phillips Countersunk Head Screw - metric
    1 Posts 1 Posters 1.3k Views 1 Watching
    • S
      slave
      Hi Guys,
      sharing another screw dynamic component that I made, this time metric.
      Standard : DIN 965 - H / A4
      Dynamic options/adjustments:
      • screw size as per standards (+/- 0.5mm)
      • screw length as per standards (+/- 0.5mm)
      • nut option
      • washer option plain/lock
      • INFO
        Label - STANDARD SIZES : relating to bolt size and length.
        (non standard combination will not generate model)
        Label - CONFIGURATION: related to parts thickness and screw length.
        (when chosen length is not sufficient)
      NOTE:
      Please be careful if using plugins for cleanup. (like : erase hidden geometry)
      Component model contain HIDDEN PARTS for some configurations.
      I didn't check all configuration for errors, mean can be.............
      If any, Please report.
      Model can be download here......
      https://3dwarehouse.sketchup.com/model.html?id=u8720003d-c973-4e70-b569-2884e7c31ce0
      Thea render
