    Cut geom. in an Instance and paste outside of all instances
    2 Posts 2 Posters 235 Views 2 Watching
    • JClementsJ
      JClements
      I made this post back in 2008.
      http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=8591%26amp;p=51308#p51308
      A few weeks ago I asked Sdmitch for some help and he came up this script
      Cut a selection within a Component Instance and Paste in Place from All Instances
      This script is located in the Edit Menu and will be only work on a selection within a "top level component" not from a selection within a component that is contained in another component.
      Open a component instance, make a selection (it can be a group, component, loose geometry or any combination of them), run the script and pick a layer to paste the selection to (the current layer is initially shown in the list).
      The script name and description in the Edit menu is a bit long so feel free to rename them.
      Thanks Sdmitch.
      Here is an test file to experiment with (SU2015 format)
      Cut SELECTION from WITHIN A Component Instance and Paste In Place outside of each Component Instance.skp
        Thanks John and especially SDmitch.
