Script won't find face
I have this one scripts,
UI.menu("PlugIns").add_item("Draw Riser") { draw_riser } def draw_riser prompts = ["length", "Run","height","Rise","Total Rises","Riser Thickness"] defaults = [36.0,10.0,1.0,7.75,7,0.5] input = UI.inputbox prompts, defaults, "Risers." a,b,c,d,e,f=input ent = Sketchup.active_model.entities #---------Clear All #Sketchup.active_model.entities.clear! #----------------Make 1st Riser ent.add_line [0,0,d-c+0.1875], [0,0,0] ent.add_line [0,-0.5,d-c+0.1875], [0,-0.5,0] ent.add_line [0,0,0], [0,-0.5,0] ent.add_line [0,0,d-c+0.1875], [0,-0.5,d-c+0.1875] #edg.find_faces; face=edg.faces[0] #face.pushpull a ##group5 = ent.add_group face.all_connected #----------------Make rest of Risers ent.add_line [0,b,2*d-c+0.1875], [0,b,d-c] ent.add_line [0,-0.5+b,2*d-c+0.1875], [0,-0.5+b,d-c] ent.add_line [0,b,d-c], [0,-0.5+b,d-c] ent.add_line [0,b,2*d-c+0.1875], [0,-0.5+b,2*d-c+0.1875] # edg.find_faces; face=edg.faces[0] #face.pushpull a #group3 = ent.add_group face.all_connected #for i in 1..e-2 # group5 = group4.copy # tran = Geom;;Transformation.translation [0, b*i, d*i] #group5.transform! tran #end endIm having issues getting the code to make the faces and then pushpull.
My idea is to make the 1st riser a group on it's own, then make the second riser a group and copy it up.
Do not add the edges to the model entities, they will intersect with the model.
Create an empty group, and immediately add a cpoint into it (to keep SU garbage collection from deleting it.)
then add the edges to the group's entities collection
then do find_faces on the edges inside the group and the face should added to the group's entities.
then do the push pull
delete the temp cpoint
then copy the group
To expand that point...
ent = Sketchup.active_model.entities **group = ent.add_group() ent = group.entities**Add the two 'BOLD' lines after the
ent =
Then everything is inside 'group', which you can 'name' etc as you wish... -
Thank you,
That worked.
Register LoginAdvertisement
