    V2015 Issues...
    3 Posts 2 Posters 350 Views 2 Watching
      driven
      forget about v2016 for the moment, has anyone noticed things that might make a v2015 service release?
      for starters, has adding a color/texture to group/component changed...
      My memory tells me I could hide a texture by coloring the group, was that ever the case?
      this is a group that was colored first the the geometry textured
      I rarely do it, but the ability seems to have vanished on my mac...
      why is it showing as colored if I have no way of seeing it's color once textured?
      john
      • pbacotP Offline
        I don't think so. If you've already put texture on the faces, coloring the group will not overide it. It will however make things interesting for you down the road... Any face inside the group that is default color (including back faces) would take the color, but if you look at the surface's Entity info it will say it has default color.
          driven
          cheers, I suspected it was an incorrect memory of something I never do...
          I was doing a rendering test where it may have been useful...
          john
