    OnElementAdded inside Group or Component
    4 Posts 2 Posters 617 Views 2 Watching
      maricanis
      I've defined EntitiesObserver class to observe when new Face object is added to entities collection.
      class DLEntitiesObserver < Sketchup;;EntitiesObserver
          def onElementAdded( ents, new_ent )
              if new_ent.class == Sketchup;;Face
                 puts "Face added #{new_ent}"
      Sketchup.active_model.entities.add_observer(DLEntitiesObserver.new() )
      This code catches when Face is added directly in model, but doesn't catch when face is added inside some Group or Component instance.
      I tried to add another observer to catch when active path is changed and to attach observer to active_entities.
      class DLModelObserver < Sketchup;;ModelObserver
          def onActivePathChanged(model)
              Sketchup.active_model.active_entities.add_observer(DLEntitiesObserver.new())
      This catches faces added inside group, but when I open and close group multiple times it adds each time new observer -> so each new face is detected multiple times.
      I've tried to find solution on forum, but didn't have success (or used wrong keywords πŸ˜„.
      So my question is how to detect when new face is added in model, or inside any group, component instance, and how to detect that exactly once?
      Thanks in advance,
      Marija
      • TIGT Online
        In the observer class code [outside of the 'def' methods], initially set up a hash as an enduring class variable...
        @@obs = {}
        Then in the method itself, remove any existing observer, so we never get more that one in each entities context...
        Sketchup.active_model.active_entities.remove_observer(@@obs[Sketchup.active_model.active_entities])
        It fails silently if there is not an observer to remove !
        Then add a new observer...
        @@obs[Sketchup.active_model.active_entities] = Sketchup.active_model.active_entities.add_observer(DLEntitiesObserver.new()
        This is untested, but it should give you the idea...
          maricanis
          Thanks TIG,
          Your post give me the idea and after few modifications and tests code looks like this:
              @@observers = {}
                  #if active_path is nill (no group or component is opened)
                  #skip adding new observer to model entities - since it is added on startup
                  if !Sketchup.active_model.active_path
                      return
                  Sketchup.active_model.active_entities.remove_observer(@@observers[Sketchup.active_model.active_entities])
                  #define observer object and try to add it to active_entities
                  #if it is successfully added, update class variable @@observers
                  observer = DLEntitiesObserver.new()
                  if Sketchup.active_model.active_entities.add_observer(observer)
                      @@observers[Sketchup.active_model.active_entities] = observer
          It works correctly and each time only single observer is defined for active_entities.
          Thanks again,
          Marija
            maricanis
            I've been experimenting on adding/removing EntitiesObservers when groups/components are opened/closed, and I've found difference in behavior in old and new Sketchup versions.
            When I have few nested groups and I open/close them multiple times (without leaving top parent group):
            • Sketchup 8 and Sketchup 2013 - observers are added/removed as expected and each new entity is detected only once
            • Sketchup 2014 and Sketchup 2015 - it seems like observers aren't removed each time 'onActivePathChanged' is called (although in console is printed that they are removed). When I add new face inside some nested group it is detected multiple times. Number of times EntitiesObserver is called is increased each time I open/close some subgroup.
              Below it the code which is independent from my plugin and can be simply loaded in Sketchup for testing purposes:
            module DL;;Daylighting
            #Attach observers to model, entities and materials
            class DLAppObserver < Sketchup;;AppObserver
                def initializeObservers(model)
                    model_observer = DL;;Daylighting;;DLModelObserver.new()
                    model_observer.initializeObservers(model)
                    model.add_observer(model_observer)
                def onNewModel(model)
                def onOpenModel(model)
                @@observers = {}
                @@entitiesObserver = nil
                    @@entitiesObserver = DL;;Daylighting;;DLEntitiesObserver.new()
                    model.entities.add_observer(@@entitiesObserver)
                #When new group is opened remove old observers and add new observer for active_entities
                    puts "active path changed"
                    #remove all previous observers
                    @@observers.each_pair{|entities,observer|
                        begin
                            puts "***entities #{entities} remove observer #{observer}; #{entities.remove_observer(observer)}"
                        rescue Exception => e
                            puts "Can't remove observer",e.message
                    @@observers={}
                    #if all groups are closed -> don't add observers
                        return
                    entities = Sketchup.active_model.active_entities
                    puts "***entities #{entities} add observer #{entitiesObserver}"
                    if entities.add_observer(entitiesObserver)
                        @@observers[entities] = entitiesObserver
                    #detect only Sketchup;;Face entities
                        puts "onElementAdded #{ents}; #{new_ent}"
            end #DL;;Daylighting
            To attach these observers to the application just in call in Ruby console
            app_observer = DL;;Daylighting;;DLAppObserver.new()
            app_observer.initializeObservers(Sketchup.active_model)
            Sketchup.add_observer(app_observer)
            I don't understand what I'm doing wrong, because printed messages in ruby console show that old observer is always removed from entities when Active path is changed, but still new faces are detected multiple times.
            Once I leave all groups and go back to model (active_path=nil), all observers are like reset and I have only one EntitiesObserver.
            When I go inside groups and subgroups again, the number of observers increases again.
            And to repeat, in Sketchup 8 and Sketchup 2013 - this problem doesn't exist.
            Any suggestion is welcome, because I'm moving in circles with this observers.
            Thanks in advance,
            Marija
