LightUp 64-bit released
With the release of SketchUp 2015 (64-bit) we can finally take the wraps of LightUp 64-bit support.
Some of you may have noticed the additional installer "LightUp-x64.msi" appearing in the Windows download. This is for installing LightUp (64-bit) for SketchUp 2015 (64-bit).On Windows, we're seeing LightUp 64-bit lighting 70% faster than previous versions!
Login to the LightUp website to update your installers.
Realtime render
Very speedy adaptation!
In case it wasn't clear, LightUp has full 64-bit support for Windows and Macintosh.
On Windows, you need to run the LightUp-x64.msi installer because Windows 64-bit applications live in a different Program Files folder, on Mac its automatic when you run SU2015.
Realtime render
Register LoginAdvertisement
