    Vue Exporter not compatible with 2014?
    extensions
    6 Posts 3 Posters 1.3k Views 3 Watching
    • KrisidiousK
      Krisidious
      Vue Exporter not compatible with 2014? My older Vue Exporter doesn't seem to work in 2014 and the e-on site forgot my purchase and won't let me re-download the plugin to see if it's newer. In their description the call it the same V10 that I already have... Anyone know what's up with the exporter?
      Wanting to try out the new 2014 Vue Xstream PLE.
      By: Kristoff Rand
      • KrisidiousK
        Krisidious
        Cornucopia3d contacted me and informed me that they had not lost anything, that it was I who had lost something. My other account. So my wallet is not gone.
        And there is an update to the Vue Exporter for 2014. Update_Vue_23_1
        http://www.cornucopia3d.com/
         Exports from Sketchup Pro or Sketchup Make
         NEW! Support for Sketchup 2014
         Works with all Artist and Professional level versions of Vue (version 10 and later)
         Full scene export including model geometry, materials, scene hierarchy, sun direction, and cameras
         Accurate conversion of the Sketchup model hierarchy with full naming and preservation of parent-child component relationships
         Ability to export using Sketchup instances for faster export and easier manipulation in Vue
         Export Sketchup sun direction for each scene page to create sun animations
         High degree of material appearance correlation with automated transparency and bump
         Ability to set Vue material properties directly in Sketchup materials
         Added support for setting material reflection intensity directly in Sketchup materials
         Added support for setting material Index of Refraction (IOR) directly in Sketchup materials
         Automatic handling of single-sided Sketchup faces (e.g. faces with different materials on each side)
         Support for Sketchup geometries, components and groups
         Exploding the model is not necessary
         Export the full model or selected portions of the model
         Export and automatic conversions of Sketchup animations directly into Vue animations
         Automatic conversion of Sketchup water materials into animated Vue water materials
         Utilities for automatically setting object and component pivot points in Vue to aid in proxy replacement
        By: Kristoff Rand
        • jujuJ
          juju
          happier ending then?
          • KrisidiousK
            Krisidious
            No... Still never worked in 2014 or 2015. I think the 2014 might be a conflict. working with support to find problem.
            By: Kristoff Rand
            • soloS
              solo
              Did not even know Vue had an exporter, I have not used it in over two years, I have Vue 9 inf, so no exporter.
              How is Vue these days? faster? my only issue was it was too slow to render.
              http://www.solos-art.com
              • KrisidiousK
                Krisidious
                No, it's a Sketchup exporter to Vue. Just upgraded my PLE to 2014 Vue. it seems a bit faster and more stable, has navigation customization. other than that have no played much.
                By: Kristoff Rand
