    Changing Scenes
    2 Posts 2 Posters 229 Views 2 Watching
    • J
      jamiewollens
      I added Google Earth site info and it changed the existing scenes.
      How do I deleat the Google Earth layer and return to original saved scenes?
      Thank you
      • pbacotP
        When you add a new layer, it becomes visible in all existing scenes.
        To delete a layer entirely: go to the layers window and press the minus sign button at the top. you will have to decide what to do with contents.
        To change all the scenes to not show that layer: Choose the scene, make the layer not visible by unchecking the box in the layer window, then update the scene. A hassle if you have numerous scenes.
        If you want to avoid this problem in a future situation (once you already have many scenes): Before you "Add Location", create the Google Earth layers (exact layer names) using the plugin "add_hidden_layer.rb". Then when you import location data it will go to the hidden layers. You can then choose what scenes in which you want the GE layers visible.
        Welcome to Sketchucation Forums, Jamie!
