    LibFredo 6 install problems
    extensions
    3 Posts 2 Posters 1.7k Views 2 Watching
      technochitlin
      Since moving to SU 14 I've been having some wierd plugin problems with libFredo. I installed the 'old' way and got this error:
      http://i.imgur.com/jqlTIZV.png
      So... I try to install via the Sketchucation plugin and I get:
      http://i.imgur.com/dq5JsoY.png
      -plus this list of errors:
      Error Loading File Fredo6_!LibFredo6.rb
      Error: #<ArgumentError: invalid byte sequence in UTF-8>
      C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
      C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
      C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
      C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in block in load_all_plugins' C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in each'
      C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in load_all_plugins' C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
      C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:in module:LibFredo6'
      C:/Users/Webb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'
      But nothing installs.
      I'm at a loss here- I never had much problem with plugins before this. I also made screenshots of my plugin directory that I can upload if needed, they just seemed kind of big.
      Any help would be appreciated.
      Jim Webb
      Meanwhile, back at the ranch, Tonto suddenly discovers that the leftover burritos didn't originally have guacamole...
      • cottyC Offline
        cotty
        You should delete the files from this attempt and use the pluginstore for a fresh install. In your second image, drag the bottom window border down to see the button...
        my SketchUp gallery
          technochitlin
          Thanks! All fixed now TYVM
          jw
