    SketchUcation Plugin Store Download
    extensions
    2 Posts 2 Posters 996 Views 2 Watching
    • C
      cquinn
      I am trying to download the SketchUcation Plugin Store Download and add it to my Mac Skp 2014 Plugins folder. No luck, and I watched the tutorial which showed "preferences" in the Tool menu. Maybe thats an old tutorial or it is for PC. Either way how do I get the Sketchucation tool plugin to run in Skp?
      Thank you!
      • BoxB
        The video is correct the only difference is that on a Mac the Preferences is in a slightly different place.
        Select Window > Preferences (Microsoft Windows) or SketchUp > Preferences (Mac OS X). The Preferences dialog box is displayed.
        Click on Extensions. The Extensions panel is displayed.
        Click on the Install Extension button. The Open dialog box is displayed.
        Locate the Ruby zip file to install (.rbz).
        Click on the Open button.
        You just need to download the .rbz file and install it using the preferences dialog. Don't put it in the plugins folder.
        Also be aware that the location of the plugins folder has changed with SU2014.
        I'm not a mac user so I can't tell you where it is, but it may explain your issue with other plugins not working correctly.
        It would help if you filled in your profile too.
