π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
How To Make Sidewalk Ramp
Hey I'm new to this forum! I am hoping one of you could help me know how I can design a Sidewalk ramp in front of a driveway.
In the photo on the top left you will see the profile of my regular sidewalk blocks. But I have no idea how to follow that 'V' groove down the slant in my sidewalk ramp. The same with my curved edge. Follow me won't make it happen. How would I go about this?
Any help is appreciative!
can you post our skp...
people will play...
john -
You can make three lines and move the middle one down...
What cotty said is the easiest or you can create two lines and use Joint Push&Pull plugin to push the surface down. For the outer edge I believe follow me would work or you can try Round Corner plugin .
