    Hide/Show only every Nth Copied Instance?
    11 Posts 5 Posters 3.3k Views 5 Watching
    • B
      bthomas3
      I hope this hasn't been covered somewhere else, but I can't find it anywhere
      To keep it simple, I have a variable that is set by the user (say 3), and I want to hide every COPY multiple of that number, including the original.
      So, I'm hiding COPY 0.0, COPY 3.0, COPY 6.0, etc.
      Suggestions? Thanks in advance.
      BT
      • Q
        quantj
        I suppose there's a math formula for this, I just don't know it. Otherwise, if you don't plan on having many copies, you can do a really long IF statement to hide copy 3, 6, 9, etc). Maybe add another variable to test copy# so that you can easily change what Nth number you want hidden.
        Thinking out loud, I'm thinking having a variable to calculate the total copies/# (like 3)='A', and with that number you'll get the total amount of copies you need hidden. And then somehow get every 3x# up to 'A' hidden...
        • A
          Anton_S
          Usage: Select any group/component, right click, and select Hide Every nth Instance option.
          Place into plugins folder...
          • B
            bthomas3
            Excellent script, thank you, but not ideal for this application. I need something in Dynamic Components so that the object (say a white picket fence) can be scaled to length AND the user can specify the interval of hidden components.
            The flip side to this is a second, overlapping set of pickets (say, blue), that show up where the others were removed. This formula is easy using COPYMultiplierdistance, but hiding the white ones that the blue ones replace is where I'm stuck.
            Thanks again
            BT
            • B
              bthomas3
              Ok, I was trying to avoid If/Then statements, but I got it to work with your suggestion, so time to move on. Here's what I have:
              Variable (var) = 2 or 3
              For the "white pickets" hidden every 2 or 3 instances:
              =IF(COPY=0,0,IF(COPY=var1,0,IF(COPY=var2,0,IF(COPY=var*3,1,0))))
              For the "blue pickets" shown every 2 or 3 instances:
              =IF(COPY=0,0,IF(COPY=var1,0,IF(COPY=var2,0,IF(COPY=var*3,0,1))))
              Thanks for your help, everyone. If there's a more elegant solution, I'm all ears. Otherwise, this will do. Thanks again!
              BT
              • P
                pcmoor
                only variable that acts as a counter is copy
                so need to make an expression using this when comparing to other variables
                know each object is copy+1
                also its a multiple of the "missing rate" (num)
                however sometimes its a perfect division other times not
                so need to make a formula which gives the decimal part of the division
                =(copy+1)/num-int((copy+1)/num)
                then use this as if statement
                hide_n.skp
                • Q
                  quantj
                  I think I kinda got something going:
                  Nth=3(or any other number)
                  Formula A: =copy/3
                  example: 8/3 = 2.6667
                  Formula B: =INT(copy/3)
                  example: 8/3 = 2
                  Formula πŸ˜„ =Formula A - Formula B
                  Hidden: =IF(Formula C = 0, 0, 1)
                  I worked once for my example, but when i changed the number of copies, it didn't auto redraw to redo the formula.
                  Hopefully someone here can finish this with native tools, it's a puzzle I'd like to see solved without plug-ins
                  • Q
                    quantj
                    Sorry pcmoor, my math stills arent tha advanced, that went over my head. 😞
                    Tried out your model (after writing my post), yours works and can update (which i couldn't figure out)
                    EDIT:
                    I get it! after i stared at the INT i realized we were on the same track, i think just seeing all the variables put into one formula confused me
                    • danielbowringD
                      danielbowring
                      You should be using a modulo operation for this. A modulo operation will give the "remainder" of integer division. SketchUp doesn't provide a mod function for DCs, so you'll have to create it as such:
                      a - (n * FLOOR(a/n))
                      where a is the index and you want to hide every N.
                      For example, if you have
                      HIDDEN=COPY - (3 * FLOOR(COPY/3))==0
                      , you'll get:
                      HIDDEN, VISIBLE, VISIBLE, HIDDEN
                      You can change the compared value (in the above example, 0) to be the "offset", but it must be less than n.
                      HIDDEN=COPY - (3 * FLOOR(COPY/3))==2
                      , you'll get:
                      VISIBLE, VISIBLE, HIDDEN, VISIBLE, ...
                      • A
                        Anton_S
                        Actually Ruby does have a modulo function. It's this symbol: %.
                        5%3 = 2
                        6%3 = 0
                        etc...
                        The script at third post uses the modulo technique to hide every nth instance.
                        • danielbowringD
                          danielbowring
                          Yes, ruby does have a modulo operator - I said Dynamic Components doesn't provide a modulus function.
