    Video Texture
    64 Posts 11 Posters 47.0k Views 11 Watching
    • KrisidiousK Offline
      Krisidious
      anyone tested it yet?
      By: Kristoff Rand
        driven
        won't run on mac, so be the first...
        you can always disable if it's a problem...
        john
          In what Menu must be shown and whith what name? Right click ?...
          And what is the process?
          Seems not existing in Su6 ๐Ÿ˜„
            schnydix
            Hello pilou Try SU 8 above make more sense ๐Ÿ˜‰
            The name is Video Texture
              Krisidious
              works like a charm on SU2015-64... frickin amazing.
              By: Kristoff Rand
                driven
                post a clip...
                  Krisidious
                  it's uploading... be a few minutes.
                  By: Kristoff Rand
                    Krisidious
                    Here's my first test. Stuttering is my screen capture software. it sucks.
                    By: Kristoff Rand
                      Yep i will try in V8 because in V6 it don't find the main.rbs
                      who is well existing! ๐Ÿ˜„
                      Edit : Sorry no more chance in the v8 !
                      Maybe in the 2014 ๐Ÿ˜„
                        Seems works in 2014 ๐Ÿ˜„
                        But some crashes of the window Loading Video! ๐Ÿ˜ฎ
                        With a simple Gif animated! ๐Ÿ˜„
                        Is that the same for you ? โ“
                        Works after closing the numerous crash windows! ๐Ÿ˜„
                        The crashes windows are with this simple gif animated! ๐Ÿ˜‰
                          schnydix
                          Hi Pilou
                          I just tested it on
                          WinXp Sketchup 8
                          Win7 Sketchup 2013
                          Win7(64) Sketchup 2014
                          Win7(64) Sketchup 2015 (64bit)
                          ... and it works everywhere for me (with the gif file you provided)
                          I have however to admit that with such 1-second anigifs, there are a bit large breaks between the repetions. Maybe we can improve for such situations one day. But it works.
                          To make it loop/repeat you must enable the loop button (rightmost button of the 7 buttons per video) which looks kind of like a recycling button ๐Ÿ˜„ If its light green its on and it will loop , if its off (dark blue) it will play only once.
                          Hmmm maybe we can never guarantee that ffmpeg will be happy on every cpu, with every video file in every format it supports. I guess there are too many combinations. (But note that ffmpeg has the problem, which is a 3rd Party application , and not invented/developed by us, only packaged)
                          Maybe Converting the file to a different format would help for you.
                            schnydix
                            Hello Pilou
                            I Think the plugin dont like bananas as well is a children please try some other Fruits.
                            Banana work fine for me in SU 2014 and 2015 wihout crash but work not in SU 8.
                            First Proplem/Bug Ani Gifs run not all (The Fruit make no difference) in SU 8 and SU 2013
                            ๐Ÿ˜„
                            esense 3d
                              Ah ok the automatic replay was on the other Window! ๐Ÿ˜ณ
                                Marc Schnyder
                                No need to be "embarrassed", we have User Manuals not yet available, that excuses anything from your side ๐Ÿ˜„
                                  Ah damned! I am very unlucky with your plugin! ๐Ÿ˜ฎ
                                  Total general crash with a little smiley animated of the forum
                                  Result = Analyse + repairs of the Hard disc + cold nervous shivers! ๐Ÿ˜•
                                  I have losted an half hour! ๐Ÿ˜ข
                                  I believe that your plugin is not enough saftety for my case! ๐Ÿ˜’
                                  I am desolated of this! ๐Ÿ˜ข
                                    Marc Schnyder
                                    Hello Pilou
                                    Let me start like that: Sorry that your system crashed, but:
                                    The Plugin as well as ffmpeg does nothing that would go so "deeply" into your system that it could crash your whole system.
                                    Some theoretical theories:
                                    • If you have unstable graphics drivers , it may crash your system... And maybe playing videos on textures "stresses" the system a bit more than showing static images.
                                    • If your System crashes , you should check the overall system stability, as no application at all is supposed to be able to crash the whole system like that.
                                    During development while programming around in the Plugins code , i had Sketchup hang and Sketchup crash , but only the application , not the whole System that you need to reboot and do a disk check.
                                    I would still believe if someone says it hangs or crashes his sketchup (and in that case just uninstall the plugin) , but i totally dont see how this should crash your system.
                                    Unless by stressing it more , but a stable system can deal with some stress.
                                    With reasonable Graphics Acceleration and not too complex 3d-Modells, the application shouldnt be stressy at all for a system at all btw...
                                    Your system does 30 min disk checks? Not sure when ive seen that last since Windows 98. What Windows System do you have? I like to mention that shortly i saw a Windows 8 Terminate itself , while all other systems felt fine... Without my plugin or sketchup anywhere ๐Ÿ˜„
                                      schnydix
                                      A lot people download , install and start the plugin
                                      No Feedback we need it Please.
                                        schnydix
                                        Hello all i downloadet the crash Gif s without the Pilou effect
                                        Running easy on my system.
                                        esense 3d
                                          Krisidious
                                          I'm running gifs on 2015-64 fine.
                                          By: Kristoff Rand
                                          • olisheaO Offline
                                            olishea
                                            I need a mac version so bad!! I can't test unfortunately. There is so much you could do with this plugin! I wish SU would natively render animated gifs as textures. ๐Ÿ˜ž
                                            oli
                                            • 2 / 4
