    Layer colors
    5 Posts 2 Posters 437 Views 2 Watching
      crazystu
      Hi all. When I make new layers there appears to be an almost random way the layer color is set. I would like to set all new layers to a default color as I make them. For example all new layers will be red. From there if I want a layer to be a different color I can change it as required. Thanks in advance for your help. cheers
      • yorik1984Y Offline
        yorik1984
        How many layers usually in your model?
          crazystu
          Layer numbers can vary depending on drawing but have one up around 50 most would likely be 30ish though. Cheers
            yorik1984
            Now i doing plugin for this.(I have done other with same action, but need to do some changes for your need). What version of SU? It works only in 2014
              crazystu
              Sorry about delay in replying. 2014 is fine. That is so very nice of you to write a plugin to do what I am after. Thank you so very much.
