    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 16.5k Views 18 Watching
    • F Offline
      faust07
      Thank you for your quick response. The clipping problem is already mitigated by the possibility of external rendering of scenes. Reducing the number of files is only for the ease of use for normal users, clients or patients ... 😉
      • rami_lpmR Offline
        rami_lpm
        No problem.
        Hey, it turns out you can inline almost everything into a single html file. See this two articles. I'll see what I can do with this.
        Offline Application
        Inliner
        • F Offline
          faust07
          That sounds great! I have looked into it ... I once - over 20 years ago - programmed a little and am now primarily user. So I understand very little and can only be amazed by your progress.
          • rami_lpmR Offline
            rami_lpm
            I just updated the plugin.
            It should be able to wrap every panorama inside one rather big html file.
            Also, I realized that I myself started learning to code 20 years ago. Now I feel old. =P
            • OxerO Offline
              Oxer
              Thanks for the plugin!!
              I use Thea Render and works fine replacing the images generated for the plugin with images generated for Thea Render, only one question, when I select Custom Template, the titles to select the different filetype don't appear in the pop-up windows, see the image.
              MAC 0S X 10.11.4 & SU2016
              [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
              • rami_lpmR Offline
                rami_lpm
                Thank you for the feedback.
                That's a strange behavior. 'custom template' requests three template files: html, css and js in that order.
                Can you try pasting this line in the ruby console and telling me if it shows the title?
                UI.openpanel("can you read this?", "~/","yes")
                • OxerO Offline
                  Oxer
                  The title doesn't appear, see the image.
                  • OxerO Offline
                    Oxer
                    It's rare, but the window title to Choose Output Folder appears when click in Make panorama icon.
                    (I have translate the plugin to Spanish language)
                    • rami_lpmR Offline
                      rami_lpm
                      So strange.
                      Makes no sense that UI.openpanel has this bug and UI.savepanel doesn't.
                      I guess it's a problem with ruby and OS X. I'll see if there is a way around it.
                      Thanks for letting me know.
                      • F Offline
                        faust07
                        Late answer after my vacation. To pack a panorama in one HTML file, works very well. Great job. 👍 Here's an example. I found no way to assign a file name from the pull-down menu. It always wants open an existing file.
                        unzip - includes panoramic html-file
                        test scene
                        • rami_lpmR Offline
                          rami_lpm
                          Thanks.
                          Nice scene!
                          Yes, filenames are a little restricted because I wrote the plugin mostly for the web.
                          What filenames would you like to change?
                          • F Offline
                            faust07
                            After some consideration the predefined names are fine. A small inconsistency is at the upper side of the cube, when I use the default SketchUp sky. This is not shown in the panoramas in the color of the sky but in the background color.
                            • brettsichellodesignB Offline
                              brettsichellodesign
                              I am getting some problems with this plugin in SU 2017. The images don't appear to be stitching together properly.
                              • rami_lpmR Offline
                                rami_lpm
                                I haven't tested it in SU 2017 yet. I'll see what I can do.
                                Thanks for the heads up.
                                • rami_lpmR Offline
                                  rami_lpm
                                  Ok, I've tested it, it appears that the exported images have a black border (bottom and right).
                                  Can anyone else confirm this?
                                  I'll try and fix it.
                                  • srxS Offline
                                    srx
                                    Yes. The edges of the box are visible.
                                    www.saurus.rs
                                    • rami_lpmR Offline
                                      rami_lpm
                                      I've found a workaround, if you set the resolution to 1020 or 2036, the edges are gone.
                                      • rami_lpmR Offline
                                        rami_lpm
                                        Hey pilou, is that on windows or mac? I've tested it on windows 10 and and the only problem was the border around images.
                                          In 2017 Upper face cube is always green!
                                            Windows 10
                                            But I have made any regulates!
                                            pano1.zip
                                            • 3 / 4
