    [Plugin] [$] S4u_Panel
    25 Posts 12 Posters 14.5k Views 12 Watching
    • hdpvH Offline
      hdpv
      (request by Laudhi Chrisdian)
      Trial and purchase:
      http://extensions.sketchup.com/en/content/s4u-panel
      https://sketchucation.com/pluginstore?pln=s4u_Panel
      Draw panel by 3 points or select face.
      +TAB key : Back - Center -Front
      +Arrow LEFT,RIGHT, UP : Lock direction X,Y,Z
      +Enter: Finish
      +Hold Shift : lock direction
      +RightMouse : get Options
      Suforyou
      http://www.sketchupforyou.com
      • JQLJ Offline
        JQL
        You're in a spree! Well done!
        www.casca.pt
        Visit us on facebook!
        • G Offline
          g.moggel
          wonderful. very useful for real architecture models where you would rebuild your 3d building into cardboards. what would be nice though is a tool to automatically create 2 of the boards sitting inside the other when using the tool last shown in the video.
          cheers,
          shut up and take my money 😉
          mo
            sancho77
            👍 She is a beauty!
            • GMthompsonG Offline
              GMthompson
              HMMMMM Its like a improved double line.rb looks like a winner
              you can learn something everyday by paying attention
              • F Offline
                function
                s4u_on_fire thanks for all the great plugins this past month!
                • hdpvH Offline
                  hdpv
                  After s4u toComponent v5.0.0 to finish 😉
                  Suforyou
                  • F Offline
                    feodos
                    The plug-in doesn't work. The table doesn't appear.. SU2014
                      chrisik
                      Same here.
                      • hdpvH Offline
                        hdpv
                        What OS do you use?
                        copy message Ruby Console (in menu Windown-> Ruby Console) send to me
                        RightMouse for get Options and Set parameter
                        Suforyou
                        • F Offline
                          feodos
                          Win7-64
                          Ruby Console:
                          Error: #<ArgumentError: Cannot convert "3.5cm" to Length>
                          c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:94:in to_l' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:94:in reset_setting'
                          c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:63:in activate' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:662:in select_tool'
                          c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:662:in main' C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb:19:in block (2 levels) in module:S4u_panel'
                          -e:1:in call' Error: #<TypeError: no implicit conversion to float from nil> c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in length='
                          c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in get_points_panel' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:199:in draw'
                          c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in length=' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in get_points_panel'
                          c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:199:in draw' Error: #<TypeError: no implicit conversion to float from nil> c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in length='
                          c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:199:in draw' Error: #<TypeError: no implicit conversion to float from nil> c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:473:in pushpull'
                          c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:473:in make_panel' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:435:in process_panel'
                          c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:379:in `onLButtonDown'
                          • hdpvH Offline
                            hdpv
                            Thanks!
                            I have fixed it.
                            Try again!
                            Suforyou
                            • F Offline
                              feodos
                              ok, thanks
                              • G Offline
                                goga63
                                when you download the new version error
                                Error Loading File C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_code.rb
                                Error; #<SyntaxError; C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_code.rb;665; syntax error, unexpected keyword_end, expecting end-of-input>
                                C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;9;in `require'
                                C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;9;in `<module;S4u_panel>'
                                C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;5;in `<module;S4U>'
                                C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;3;in `<top (required)>'
                                C;/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb;197;in `require'
                                C;/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb;197;in `load'
                                C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;16;in `register_extension'
                                C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;16;in `<module;S4u_panel>'
                                C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;4;in `<module;S4U>'
                                C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;3;in `<top (required)>'
                                • hdpvH Offline
                                  hdpv
                                  Run as Administrator Sketchup
                                  install plugin and restart.
                                  I don't know this error.
                                  Suforyou
                                  • G Offline
                                    goga63
                                    thanks, it works now.
                                    • designerbursaD Offline
                                      designerbursa
                                      s4u please part list an cutting nesting
                                      Than you
                                      • hdpvH Offline
                                        hdpv
                                        i don't understand!
                                        Suforyou
                                        • G Offline
                                          greatoe
                                          the TAB key for Front-Middle-Back never work on a Mac
                                          • hdpvH Offline
                                            hdpv
                                            Did you update the new version?
                                            What is your system?
                                            Suforyou
                                            • 1 / 2
