    Obligatory Hoverbike
    83 Posts 16 Posters 16.0k Views 16 Watching
    • Bryan KB Offline
      (this post is a second attempt. for some reason the first one deleted or dropped from last night)
      Well it's that time for the obligatory hoverbike to add to my portfolio. πŸ˜„
      As usual, I'll start with the rough block-outs. I hope to make this as detailed as the camera.
      (Thanks to Max Grueter for the rider from the warehouse)
      • Bryan KB Offline
        Still adjusting mass and proportions.
        • Bryan KB Offline
          Still proportioning.
            Interesting, what kind of 'landing gear' are you going to use, seems to cry out for outrigger skids a 'la helicopter.
            • Bryan KB Offline
              Thanks.
              Pads on the lifting pods.
              • Bryan KB Offline
                More blocking.
                • Bryan KB Offline
                  Underview.
                    An existant model or pure imaginative ?
                    • Bryan KB Offline
                      Original by me.
                      But remember, this is just the block out. A lot more detail and shaping is still left to be done.
                      • Bryan KB Offline
                        I'm happy with the overall mass and scale, There are some other things not shown that will change the overall style, but I'm moving ahead with the details.
                        • Bryan KB Offline
                          Reworked instrument cluster. Roughing in the seat.
                          • Bryan KB Offline
                            2 other angles.
                            • Bryan KB Offline
                              Reworked the instrument cluster and seat. Added rider pedal brackets.
                              • ely862meE Offline
                                ely862me
                                Great start.
                                Two things I believe could be better:
                                1. The gauges should be a bit more vertical. The actual position will force the rider to take a longer time to read them. Ideally they will be closer to the eyesight driving position.
                                2. The footrests should be more horizontal, otherwise it will be nearly impossible to climb on and maintain the feet onto them.
                                Going quite nice otherwise !
                                And perhaps a bigger "engine" in the back ? That would be the one holding more mass whilst the front ones are used to support some of the mass and steer.
                                But hey, it's your imagination, go wild, I like it !
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                  Defo miving on mate, sleek.
                                  • Bryan KB Offline
                                    Thanks guys.
                                    This is still a long way from finished.
                                    • Bryan KB Offline
                                      Still roughing in the details and playing around with the tail.
                                      • Bryan KB Offline
                                        Working on tightening up and unifying the tail.
                                        • Bryan KB Offline
                                          Ah, that's better.
                                          • Bryan KB Offline
                                            Updates. Added landing skids and detailed grav pods, front scoops and minor tweak to rear end.
                                            • 1 / 5
