    Creating A Carpark Ramp
    3 Posts 3 Posters 357 Views 3 Watching
    • O Offline
      oo7ml
      I need to create a carpark ramp.
      The ramp is basically like a semi circle that comes out of the ground floor and then swings up and around 180 degrees to the next floor, which is supported by pillars.
      Once you get to the next floor, you can drive out again onto theramp and then swing up and around 180 degrees again to the next floor.
      There is an identical ramp at the other side of the building, which allows you to go back down the floors.
      What would be the best way to create this ramp, thanks in advance for your help.
      • BoxB Offline
        There are quite a few ways to do what you want and what is best depends on exactly what result you want and your level of expertise.
        One of the most straight forward ways is with Radial Bend, part of FredoScale.
        But I repeat, this is only one of many ways.
        • cottyC Offline
          cotty
          Another possibility:
          http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=57658%26amp;hilit=+follow+me+keep#p524527
          my SketchUp gallery
