    Changing the shape of an organic model
    Scheduled Pinned Locked Moved Organic Modelling
    3 Posts 3 Posters 8.2k Views 3 Watching
    • K Offline
      kellenraidfractal
      I have a relatively flat 3D shape. I want to elongate one side of it thus making it asymmetrical. Non-symmetry is what I want. But when I select one side to use Fredoscale, the remainder of the model is distorted by being stuck together.
      So solve this, I could go back to the rails and then distort them, then remake the surface. Is there a plug in, like artisan tools, say, that would solve this?
      • ely862meE Offline
        ely862me
        It is a bit hard to understand or even impossible without seeing an example or the model, if possible !
        Usually for using fredo's scale you need to have the model segmented or use segmentation, press Tab and change the segmentation from -3 to whatever you think it is appropriate for you.
        Elisei (sketchupper)
        Come and See EliseiDesign
        • pbacotP Offline
          Vertex tools might help. but that is just a guess without further info.
