Really interested in GPU using VFSU
 I tweaked a few materials, ran Presto for 18 minutes only GPU (did not use CPU and GPU as I wanted to test Titan on it's own at low priority) 3000x1875 Device #0; GeForce GTX TITAN Building Environment... done. (0.648 seconds) - Polys; 564124, Objects; 1098, Parametric; 0 - Moving; 0, Displaced; 0, Clipped; 0 - Instances; 0, Portals; 0 - Nodes; 165922, Leaves; 165908, Cache Level; Normal Device #0; memory ?/4095 Mb Device #0; 372x4 s/p Finished in 1115 seconds Finished in 18 minutes and 37 seconds! Funny how in Thea4SU my card shows 4GB ram and not 6GB, is that a Sketchup limitation?
 It would be interesting to see how well CPU+GPU does.
 @solo said: I tweaked a few materials, ran Presto for 18 minutes only GPU (did not use CPU and GPU as I wanted to test Titan on it's own at low priority) 3000x1875 Hi- res , clear, crispy image. At 18m 37 secs. That is impressive. Thanks for trying out.
 Now I'd like to consider Titan.. and probably Thea too.And I wish there's somebody who could tryout vray GPU . At least with these few infos, I can come up with a recommendation to my boss in terms of GPU hardwares Thanks a lot
