    Mad behaviour of String#hash
    6 Posts 4 Posters 735 Views 4 Watching
    • AdamBA Offline
      AdamB
      I recently fixed a bug in LightUp that was the result of a subtle change in the method #hash between Ruby 1.8 and 2.0 that I thought I'd share.
      Previously, "adam".hash would always give the same result - because its a hash of the string "adam" - which is what you'd expect.
      Ruby 2.0, chooses to give you a different result every time you launch Ruby. Which is quite idiotic.
      The upshot is you cannot rely on creating digests that persist across sessions. 😠
      Sadly, there is no doubt a thread somewhere in Rubyland explaining why its a stroke of brilliance.. sigh
      • Dan RathbunD Offline
        Dan Rathbun
        Try:
        https://bugs.ruby-lang.org/search?utf8=%E2%9C%93%26amp;q=String%23hash
        I'm not here much anymore.
          Or for an explanation see this http://stackoverflow.com/questions/6783811/why-is-ruby-string-hash-inconsistent-across-machines
          • tt_suT Offline
            tt_su
            Oh... I might have to have a scan of my extensions. I'm not sure if I store string hashes, but I wouldn't be surprised.
            This .hash change affects only String, yes?
            Thanks for the heads up.
              Dan Rathbun
              Which actually quotes from the Ruby bugs dB at:
              Bug #4103 (Closed): String#hash not returning consistent values in different sessions
                Dan Rathbun
                The above Ruby bugs thread mentions Object#hash being overhauled (which is inherited by every object, unless overriden.)
                So a test under SketchUp 2014 & Ruby 2.0:
                (1) Open a SketchUp session, and in the console:
                Sketchup.hash %(#004000)[>> -112701995]
                This is the method that the Module class inherits from Object.
                (2) Close this SketchUp session, reopen SketchUp, and in the console:
                Sketchup.hash %(#004000)[>> -226388390]
