    C program to convert skp to dae
    1 Posts 1 Posters 720 Views 1 Watching
    • G Offline
      gedw99
      hey all
      i have reached the end of what i can do in ruby, and need to code in c.
      i am new to c πŸ˜„
      The thing i need is basically to convert skp to dae. I am sick of having to export manually from inside sketchup, since i do allot of work with webgl and collada.
      so any tips on starting to write using the sketchup c sdk?
      ide to use ? Prefer none. No heavy visual studio.
      will the c exe be able to run without sketchup open?
      There is a skp2dae.dll in the normal program files installation of sketchup. I assume i cant use that because it needs sketchup loaded, i assume ?
