    GUYS! How do I Sketchup?
    4 Posts 2 Posters 770 Views 2 Watching
    • A
      Alexey007
      Hey everyone. I'm having a bit of trouble figuiring out where the question section is so I decided to have a drink at the Corner Bar with you.
      The Issue I'm dealing with is related to making holes in objects. Say I have a circle - I copy it, scale it down, put the baby circle in the middle of papa circle - press delete - and papa circle has a hole in it.
      BUT when I'm dealing with more complex objects it doesn't work (see attachment). I guess I need to get rid of the geometry lines inside. Is there a magic button which removes lines inner lines of the object leaving only the outline? Or something.
      http://i58.tinypic.com/33tkyo7.jpg
      And while I'm here - Question 2 - how do I make an object manifold solid? Magic button pls. I want to make the heart a manifold solid (see attachment 2).
      Solution would be easy.skp
        For the Clean : CleanUp 3 by Thomthom πŸ˜‰
          You can play with Extrude Tools by TIG (better if each curves 2 by 2 have same number of segments!
          (weld each curve with Recurve by Diggsey
          Just mirror copy / symmetry after πŸ˜„
          • A
            Alexey007
            Thank you, Pilou.
            I'll let you know how it went.
